Go Back   kingpincooling.com > kingpincooling.com Products > Product Support
Product Support Problem with your KingpinCooling.com products? Jump in here...
Old 03-11-2012, 10:57 AM
reggiesanchez reggiesanchez is offline
Default Tek hardware replacement
Really want ot order a set or two of extra screws and bolts for tek's but shipping is coming up as 30 dollars for two packs of screws.A little help Or can someone just link me to another set of screws that will fit. Ive tried all of the ones I can get locally and nothing works right. What size are they
Old 03-11-2012, 01:29 PM
Bobnova Bobnova is offline
Look for a local fastener supply store, they can probably order them. The sizes are quite goofy. So, for that matter, is $30 of shipping for something weighing a couple ounces.
Old 03-11-2012, 02:25 PM
Hondacity's Avatar
Hondacity Hondacity is offline
Worries Too Much About User Title
my local nuts&bots store carries everything including metric screws. thats where i get my tek screws.
Old 03-11-2012, 05:37 PM
Do you remember what size. I dont have anything around here that would sell it. Other then home depot, lowes and radio shack none had em radioshack had ones that were close but cant find any nuts for em. And they didnt really fit just fit through the screw hole
Old 03-11-2012, 07:18 PM
Hondacity's Avatar
i don't know the size. i just brought a sample and they gave me 8pcs for like 2$
Old 03-11-2012, 08:52 PM
Send me an email or PM man, I'll hook it up cheaper..
Old 03-13-2012, 07:36 PM
Problem solved thanks a ton.
