Cart 0
F1 Gemini 2.0 Anodized Blue
$ 239.00
F1 Gemini CPU container is designed to work with a wide range of processors having different performance characteristics under extreme cooling temperatures. The F1 Gemini is a modular CPU unit designed for ultimate versatility. It has BOTH pure speed and easy temperature control via two differently individually tuned bases, creating a more versatile CPU pot. F1 Gemini kits ship with TWO solid copper design bases for LN2 use, one FAST base (for cpus without coldbugs where very fast pull down is needed) and one SLOW base (for cpus where stringent temperature control is needed due to processor coldbug).
Kit comes as pictured including (2) nickel plated copper bases, F1 black anodized body, upper BLUE anodized hold down, black anodized alu backplate, and all necessary mounting hardware including compression springs, shoulder spacers, thumbnuts, threaded mounting rods, and rubber shock insulator pad. Upper and lower bracket set included is compatible with sockets 754, 939, 775, 1366, 1156,2011,1151,1155,1156, Am2 and AM3. (F1 extension as pictured is not included in standard gemini kit)
Share this Product
More from this collection
