KPC INFERNO Socket Heater
$ 109.00
KPC INFERNO socket heater kit. We've designed a fully auto modular socket heating system for motherboards when using sub zero cooling, which can self adjust thermal loading based on the cpu's cooling temperature. This revolutionary plate can minimize dangerous moisture and condensation associated with extreme pc cooling. It also helps to keep the signaling strong between cpu socket and dimm slots when exposed to extreme temperatures. The KPC INFERNO works at a wide range of temps -40c to below -200c and beyond. This bolt on extreme upgrade is compatible with ALL KPC cpu containers. Kit comes as pictured.
