T-REX Rev. 3 x INFERNO BLACK
T-REX Rev. 3 is the latest CPU container from KPC. It was designed to be the successor to BOTH the venom and the F1 series of CPU pots and has strong extreme overclocking for both massive HCC cpus(36 thread+) as well as mainstream desktop cpus (FULL pot + high MHZ capabilities). T-REX features a massive solid copper base design that utilizes internal surface area for both tight temperature control and good speed(rate at which the pots temp can move up and down). Kit comes complete with solid copper nickel plated T-REX base, anodized INFERNO heater backplate kit, BLACK anodized T-REX top, and all necessary mounting hardware including compression springs, shoulder spacers, thumb nuts, and threaded mounting rods. Hold down set included is compatible with sockets 754, 939, 775, 1366, 1156, 2011, 2066 1151,1155,1156,1200, AM2, AM3, all RYZEN series and Threadripper(requires M3.5 rods).
**This new version supports RYZEN 3 natively, no RYZEN adapter bracket required.
