Cart 0
TEK-9 FAT
TEK-9 FAT
$ 249.00
This is the sixth revision of the TEK-9 FAT full size gpu unit for both liquid nitrogen and dry ice. Tuned for the hottest running graphics cards under extreme cooling temperatures. Gives the best performance for single GPU overclocking and dual spaced multi gpu (2x SLI) applications where highest possible clocks and highest voltages/loads are being used. Container kit includes Tek FAT 6.0 gpu unit with nickel plated solid copper design base/ anodized aluminum top(permanently fixed), 3 aluminum front side brackets pictured, and all required mounting hardware including thumb nuts and screws.
Share this Product
More from this collection
