    Home/Extreme PC Cooling/T-REX Rev. 4 CPU container RED
    $ 379.00
    SHIPPING NOW!!
    KPC T-REX Rev. 4. CPU container brings the best possible performance in a complete easy to use cpu container kit at an amazing price. We have completely updated the massive solid copper base for higher loading capacity and increased LN2 efficiency and also added future socket support. You asked for it, you got it...now there is more internal surface area for quicker temperature pulldowns(it can pull down to full pot with about 1-1.5L of ln2 only). The new internal design also greatly reduces load-idle change under extremely heavy loading with all cpus. T-rex 4 also features support for upcoming LGA 1700.
    Designed to be the successor to BOTH the venom and the F1 series of CPU pots and has strong extreme overclocking for both massive HCC cpus(36 thread+) as well as mainstream desktop cpus (FULL pot + high MHZ capabilities). T-REX features a massive solid copper base design that utilizes internal surface area for both tight temperature control and good speed(rate at which the pots temp can move up and down). Kit comes complete with solid copper nickel plated T-REX base, black anodized aluminum back plate, RED anodized T-REX top, and all necessary mounting hardware including compression springs, shoulder spacers, thumb nuts, and threaded mounting rods. Hold down set included is compatible with sockets 754, 939, 775, 1366, 1156, 2011, 2066 1151,1155,1156,1700,1200 + AM2, AM3, all RYZEN series and Thread ripper(requires M3.5 rods not included).
    **This new version supports RYZEN 3 natively, no RYZEN adapter bracket required.
    Copyright © 2023 Kingpin cooling. Powered by Shopify
    KPC store maintenance
    KPC store will be closed for maintenance temporarily. Check the dealers page for local availability of KPx thermal grease and other KPC products.
